Michael’s Corner #20
August 2004
The User Coordinate System is overlooked frequently when, in fact, there's lots of power if you know where to look. This month we take a look at a few of the integral parts of this feature. Also this month I just wanted to mention that there's a whole array of "underground" features that can be found on just the Command line. If you have some favorite Command line only routines that you can't do without, pass 'em along.
In an effort to dispel the overriding myth that the UCS deserves to be turned Off unless you're working in 3D, I'd like to show you a very simple yet powerful 2D application.
Life doesn't hand us perfectly orthogonal drawings all the time. For those unique situations – or not so unique situations in the mapping and civil engineering fields – the following procedure will enable you to bring a non-orthogonal line to be horizontal in the drawing window.
The second illustration displays the origin of the UCS anchored on the nearest endpoint of the line selected. The positive portion of the X-axis is pointing toward the opposite endpoint of the selected line.
AutoCAD will perform a
, but the X-axis of the UCS will be horizontal in the drawing.Other things to consider:
Found under the Tools section of the Express pulldown menu, the Real-Time UCS utility enables you to graphically reorient the UCS by dragging the coordinate system around the current axis of rotation.
Note: For the sake of clarity, I've set the Shademode variable to 3D for the rendered UCS icon.
When launched, the RTUCS command displays 3 long axes, with the X-axis highlighted. The highlighted axis is the one around which the rotation occurs. The default option is <Drag to rotate>. The natural tendency is to try to make your cursor go around the axis in an effort, albeit feeble, to rotate the others. In fact, the most effective method is to click and drag your cursor horizontally or vertically.
As you drag your cursor, you will notice the coordinate system incrementally rotate about the X-axis. The default increment value of 15 degrees can be changed with the Angle option.
To change the Origin of the UCS, type O but don't press <Enter>. Contrary to other option strings in AutoCAD, these options initiate as soon as you type their letter. To use another axis for rotation, use Tab. As you might suspect, the Tab key will cycle through the axes repeatedly.
[Save/Restore/Delete/Cycle/Angle/Origin/View/ World/Undo]
You will notice a similarity between these options and the normal UCS command options. The one unique feature in the RTUCS command is the Cycle option. Type C to cycle through the 6 predefined positions of the UCS: World (Top), Front, Right, Back, Left, and Bottom. These positions will be displayed on the left side of the status bar.
For an exhaustive review of the Express Tools for AutoCAD 2004 (all of which will apply to AutoCAD 2005), go to the following link and download Chapter 47 from the AutoCAD Instructor book, by James A. Leach. Jim asked me to update this chapter from the old Bonus tools so I reviewed and extensively edited the text to reflect the Express Tools as they appeared in AutoCAD 2004.
And how on earth are you going to know what commands those are?? Well, unless you have been around for a really long time… you won't.
Observed Fact: Length of time you have worked with AutoCAD is actually .35 x dog years.
Knowing the command line version of a command comes in real handy when writing Lisp routines or creating a macro for a button. Many commands that result in a dialog box have a command line version that is preceded by a hyphen. For example, using –LA will result in the old Layer command. Use –H to get the old Hatch command where you will actually find the ability to create a ‘direct hatch'; one that you create the boundary for while you are in the command.
Other commands have just been rolled off the map, but they're still in AutoCAD. The CHANGE command, for example, has an option for Properties. In that collection you have the option for Elevation or the Z position of the selected objects. If you ever get drawings in which the objects are not all in the same plane, create a Lisp routine to select all objects, then set their Elevation to 0.
As for the Express Tools, go to the Help menu for Express, then expand the Categories node to see another node for "Command Line Only" with some real pearls in there.
One of the first things to remember is that the only setting for the UCS icon that is constant across all drawings are those that are set in the UCS Icon dialog box which is accessed via the Properties option. All other options are per drawing. In the UCS Icon dialog box you can specify the icon graphic, its width size and color. You also have an option for the color in Model and Paper space.
[ON/OFF/Noorigin/ORigin/Properties]
Other things to consider with the UCS icon:
Note: If the UCS icon does not anchor to the UCS origin, it is probably because the graphic of the icon itself cannot be completely displayed based upon the position of the UCS origin within the display. Pan your drawing and the icon will probably re-appear on the Origin.
