Michael’s Corner #58
October 2007
Customizing AutoCAD is not really that difficult. I'm not talking about anything fancy like Lisp routines or VBA, just using the features that are available to tweak a few more RPM's out of this thing. For example, if you want to populate all the title blocks on the various layout tabs with the project name automatically, how would you do that? Take a look at the opening article. Then in the Power Tool I propose a method to get the same arc length(s) for a revision cloud every time on any drawing life throws at you - and on the proper layer, even if the layer isn't in that drawing. Not rocket science, just eliminating the aggravation we encounter every now and then.
Then I wanted to follow-up an article from a couple years ago on cycling through stacked objects. Autodesk decided to make it a bit like rubbing your belly and patting your head; you'll see what I mean if you look over the Odd Spot. And then I have been remiss in not letting you all know how to lock the viewport display so you don't obliterate the plot scale when you roll your wheel mouse in a viewport.
Now go out there and share what you've learned just so you can brighten up somebody else's day. You'll be their hero.
Here's what we know: Fields are text objects that are associated with information associated with the current drawing or objects in the current drawing. Information such as the Filename and Create Date, just two of the Field names in the extensive list of available bits of information.
But what if you need to link a Field to something that's not in that list, but is pertinent to the drawing, such as the Designer's Name? Many of my customers have attributed title blocks with a common attribute such as DESIGNER. That attribute occurs on all the title block sizes from A to E. Here's how to get the Designer's name (or the Project Name or any other attribute that's consistent in all the title blocks) to automatically populate that field.
To do this, we will implement the little-used Drawing Properties feature and create a Custom property, then access the value for that custom property for the Field.
Note: On the Summary tab you will find several areas in which you can add information regarding the current drawing. All of these areas - Title, Author, Subject, Keywords, Comments, and Hyperlink Base - are listed under Field names in the Field dialog box.
Job done!
Idea: When creating your title blocks (or editing your existing ones) accommodate the default Summary values listed above by using them as the attribute definitions in each title block size. This way, when you enter the project name in, say, the Subject field, the project name will appear in all the title blocks where you have used "SUBJECT" as the attribute definition.
The Revision Cloud command is a wonderful routine, but the most aggravating feature is that the Arc Length is about as fickle as the weather. One day it could be 1/2″ the next it's set to 487′. (It's actually related to the current Dimscale, but let's not go there.)
I've always wanted to run a series in the Power Tool section on fun macros or modified commands you can add to your tool palette, so here's the first one.
The first step is getting the Revision Cloud button onto your tool palette, then we'll modify the Command String. [For additional button and palette insights, I have written about custom buttons on a palette in January 2006, August 2006, and April 2007.]
At this point, you've done nothing more than copy the button onto the palette. Now we need to modify the Command String to specify the Arc length and Style, as well as specify the desired Layer, Color, and Linetype. Before editing the Command String, however, you need to know what the prompts are for the Revision Cloud command itself. It reads…
Minimum arc length: 2′-0″ Maximum arc length: 6′-0″ Style: CalligraphyWhen editing the command string "macro", think of what you would type at the Command line in response to the prompts.
^C^C - Cancel; essentially hits the ESC key
_revcloud - The underscore in front of the command means to use the English version of the command. You can delete it.
space - You will also notice there's a space after the command; you can back that out, too. (See the semi-colon comment below.)
; - Presses Enter; it's easier to discern a semi-colon than a space when pressing Enter in a macro
A - The Arc option of the Revcloud command
24 - Specifying the minimum arc length
72 - Specifying the maximum arc length (the maximum arc length cannot exceed 3x the minimum. Your call)
S - The Style option of the Revcloud command
C - The Calligraphy option (you can use N for the Normal option if you prefer)
Note: Nothing follows the last character
At this point you have a button on a tool palette that launches the Revcloud command, specifies the Min/Max arc length, and also specifies the Style to be used.
Bonus Points: Create a layer in the current drawing named "Revision" and give it a color. Edit the General area of the Tool Properties window to read as shown in the figure, then click OK. You will then have a button that can be used to create a revision cloud on the proper layer (yes, even if it's not in the current drawing) in addition to those features specified in the command string. Way cool.
It's been awhile since I covered this [specifically, about four years - December 2003], but prior to AutoCAD 2007, to cycle between objects that were essentially stacked on each other, you held down the Ctrl key, then clicked to cycle between those objects. Beginning in A2007, there was a bit of a change.
For those of you with A2007 and beyond, if you have objects that are stacked (i.e., the edge of the reflected ceiling plan layer is also where the wall line is, which is also where the carpet line is, etc.), here's what you need to do to select objects that essentially occupy the same X,Y location.
…which is not totally unlike rubbing your belly and patting your head while jumping on one leg.
From the "Don't you hate it when…" files. On a layout tab, you get your viewport perfectly set with the plot scale, then you click in the viewport and roll your wheel mouse… and totally mess up your plot scale!?!
Solution: Lock your Viewport.
Since you will be using the shortcut menu in this routing, this option requires that the Edit Mode of the Right-Click Customization (
button) be set as shown.If, for some reason that I'm sure is perfectly valid (although none come to mind), you have turned off the Right-Click Customization and you don't get a shortcut menu when you select an object, use this option.
Note: For another viewport tidbit, take a look at the Power Tool in April 2005 on maximizing viewports… because that routine works even if the viewport is locked! Very nice.
A Cake Baking Icon - Duncan Hines was a Kentucky native. Hines worked as a traveling salesman in the 1940's before lending his name to a line of sugary treats. www.duncanhines.com/newDuncan/pub/about-us/.
